はじめに
Use this guide to install, remove, or replace the phone's antenna.
必要な工具と部品
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
この手順で使用する道具:Tweezers$4.99
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
Remove the two 4.0 mm screws, one silver and one black, from both ends of the antenna using the Phillips 00 screwdriver.
ある他の人がこのガイドを完成しました。
