メインコンテンツにスキップ
Samsung BN59-01199F Keypad Replacement
必要な工具と部品
  1. Samsung BN59-01199F Keypad Replacement, Keypad: 手順 1、 1の画像 1
    • Remove the batteries before you disassemble the remote.
    • Use an opening pick in the seam of the controller and work it around the perimeter.
    • With the opening pick, scrape and remove the glue and undo the clips holding the top and bottom of the remote together.
  2. Samsung BN59-01199F Keypad Replacement: 手順 2、 2の画像 1 Samsung BN59-01199F Keypad Replacement: 手順 2、 2の画像 2
    • Use additional opening picks to keep the seam open.
    • Don't use a screwdriver or metal spudger for prying especially because the motherboard is directly underneath and could be damaged in the process.
    • Use a spudger or opening pick to work your way around the seam of the remote.
    • Separate the two sides of the remote.
  3. Samsung BN59-01199F Keypad Replacement: 手順 3、 3の画像 1 Samsung BN59-01199F Keypad Replacement: 手順 3、 3の画像 2 Samsung BN59-01199F Keypad Replacement: 手順 3、 3の画像 3
    • Remove the motherboard, the plastic button case, and finally the buttons from the plastic case.
    • Place the new keypad into the keypad holder and press to make sure it's set in securely.
  4. Samsung BN59-01199F Keypad Replacement: 手順 4、 2の画像 1 Samsung BN59-01199F Keypad Replacement: 手順 4、 2の画像 2
    • After replacing the rubber keypad, reassemble the remote.
    • Make sure to insert the light in the small hole during reassembly.
  5. Samsung BN59-01199F Keypad Replacement: 手順 5、 3の画像 1 Samsung BN59-01199F Keypad Replacement: 手順 5、 3の画像 2 Samsung BN59-01199F Keypad Replacement: 手順 5、 3の画像 3
    • When joining the two halves of the remote together line the spring up with the appropriate slot.
    • Carefully, press the two parts of the remote together.
  6. Samsung BN59-01199F Keypad Replacement: 手順 6、 1の画像 1
    • Make sure the remote is working after you put it back together and replaced the batteries.
終わりに
作成者
1人の作成者と共同作成されました。
yeisom Garrido
メンバー登録日: 10/26/22
183 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-46, Briggs Fall 2022 CSU Los Angeles, Team 1-46, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22S1G46
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 33
今までの合計 891
