はじめに
If you have gone through the troubleshooting guide, and have determined that the reason your device is not able to power on is in fact a faulty power cord then you can replace it for a new undamaged one with the help of this simple, easy to follow guide.
Make sure the device is not plugged in before working on it.
必要な工具と部品
Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
Remove the cover by sliding it up and then out.
Pull clip to remove the WiFi card ribbon connected to the circuit board.
Push the black plastic tab out and slide the WiFi card out from the cage.
Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
Lift the cage up to remove it.
