はじめに
In the event of a catastrophic failure on your Blu-ray player, the Main Logic Board may have failed. This guide is for replacing a damaged or broken Main Logic Board. The only tool required is a #1 Phillips head screwdriver.
必要な工具と部品
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
