メインコンテンツにスキップ
Samsung BD-F5900 Main Logic Board Replacement
必要な工具と部品
  1. Samsung BD-F5900 Main Logic Board Replacement, Top Cover: 手順 1、 1の画像 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Main Logic Board Replacement: 手順 2、 1の画像 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Main Logic Board Replacement, Power Supply: 手順 3、 2の画像 1 Samsung BD-F5900 Main Logic Board Replacement, Power Supply: 手順 3、 2の画像 2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Main Logic Board Replacement: 手順 4、 1の画像 1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Main Logic Board Replacement: 手順 5、 3の画像 1 Samsung BD-F5900 Main Logic Board Replacement: 手順 5、 3の画像 2 Samsung BD-F5900 Main Logic Board Replacement: 手順 5、 3の画像 3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
  6. Samsung BD-F5900 Main Logic Board Replacement, Main Logic Board: 手順 6、 1の画像 1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  7. Samsung BD-F5900 Main Logic Board Replacement: 手順 7、 1の画像 1
    • Disconnect the WiFi board cable connector
  8. Samsung BD-F5900 Main Logic Board Replacement: 手順 8、 2の画像 1 Samsung BD-F5900 Main Logic Board Replacement: 手順 8、 2の画像 2
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
終わりに
作成者
2人の作成者と共同で作成されました。
Louis McKean
メンバー登録日: 10/18/17
528 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G21, Cagle Fall 2017 USF Tampa, Team S1-G21, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G21
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 390
