はじめに
A device that fails to power on is not very useful. The Samsung BD-E5400 does not have a battery, so a possible source could be a damaged power cord. This guide will show you how to replace your power cord and restore your Samsung BD-E400 to its former glory!
必要な工具と部品
Remove the two 10mm Phillips #1 screws.
Remove the one 8 mm Phillips #1 screw.
Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
Remove the two 8 mm long, #1 Phillips head screws.
Lift up the plastic component cover to remove and lay aside.
