メインコンテンツにスキップ
Samsung BD-D5500 Motherboard Replacement
必要な工具と部品
  1. Samsung BD-D5500 Motherboard Replacement, Samsung BD-D5500 Disassembly: 手順 1、 1の画像 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Motherboard Replacement: 手順 2、 2の画像 1 Samsung BD-D5500 Motherboard Replacement: 手順 2、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Motherboard Replacement, Motherboard: 手順 3、 1の画像 1
    • Locate the motherboard within the red rectangle.
    • Locate the power supply within the orange rectangle.
  4. Samsung BD-D5500 Motherboard Replacement: 手順 4、 1の画像 1
    • The screws securing the motherboard in are labeled with red circles and the wires are labeled with orange rectangles.
    • Use your screwdriver with a PH2 sized head and unscrew these 1.2mm screws labeled with red circles.
    • Detach the wires connected the motherboard from the disc drive that are labeled in orange.
  5. Samsung BD-D5500 Motherboard Replacement: 手順 5、 2の画像 1 Samsung BD-D5500 Motherboard Replacement: 手順 5、 2の画像 2
    • Labeled with a red rectangle is the location where they are connected. Grab the motherboard in one hand and the power supply in the other, and pull the motherboard up and push the power supply down. The motherboard and power supply should then disconnect.
終わりに
作成者
1人の作成者と共同作成されました。
Trevor Neman
メンバー登録日: 01/29/18
284 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S2-G5, Bedsole Spring 2018 University of Alabama, Team S2-G5, Bedsole Spring 2018人のメンバー
UA-BEDSOLE-S18S2G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 598
