メインコンテンツにスキップ
Samsung BD-D5500 Disassembly
必要な工具と部品
  1. Samsung BD-D5500 Disassembly, Samsung BD-D5500 Disassembly: 手順 1、 1の画像 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disassembly: 手順 2、 2の画像 1 Samsung BD-D5500 Disassembly: 手順 2、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Kenya Wilson
メンバー登録日: 01/29/18
226 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team S2-G5, Bedsole Spring 2018 University of Alabama, Team S2-G5, Bedsole Spring 2018人のメンバー
UA-BEDSOLE-S18S2G5
4 メンバー
6のガイドは作成済み
2 件のコメント
I had trouble putting the vent side back in, it didn’t fit correcly. If it wasn’t late I would of done a proper disassemble. Plus it’s not a full one where it shows taking off the side panels and the front panel to access the touch screen.
if you are having issues with the model shutting off and on, you don’t have to remove the front panel you can get access to the gray plug after you take off all the top and side panels.
mush god - 返信
I can’t edit my comment….
brown plug not gray. In Step 3 picture once you reach there just unplug the white wire at the front of the player than you can easily unplug the brown plug to disable the touch buttons. Than just reconnect the white wire and reassemble.
mush god - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 15
今までの合計 2,740
