この手順で使用する道具:
購入する
Pull the two halves of the phone apart.
The phone will not slide straight apart. You have to angle the back half up a little.
Do not force it. Jiggle it a little if it doesn't come apart.
Remove the two 2.71 mm screws on the hinge using screwdriver.
Under these screws will be a washer, spring, and small metal disc. Make sure you don't lose these.
Remove the Verizon logo from the back of phone using the plastic opening tool.
The logo is attached with glue. It will be sticky, but it just pulls off.
Remove the four 4.44 mm screws from the back.
Remove the three 4.35mm screws from under the Verizon logo.
Make sure you don't mix the screws together.
Pull the back off by using the plastic opening tool.
Do not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
