はじめに
If you carry a Samsung Admire, this guide can help you step by step on how to replace your phone's screen if it ever cracks, feels in any way uncomfortable, or is unadjusted.
Before using this guide make sure:
- to have the correct Samsung Admire phone model (Samsung Admire SCH-R720)
- to power off your phone completely and disconnect any external power sources
- to have the screen replacement ready ( please complete research to make sure you have correct screen replacement)
必要な工具と部品
Use the plastic opening tool to remove the inside back cover.
Use the plastic opening to pry the front and the back case apart.
As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
12 の人々がこのガイドを完成させました。
