メインコンテンツにスキップ
Samsung Admire Screen Replacement
必要な工具と部品
  1. Samsung Admire Screen Replacement, Screen: 手順 1、 1の画像 1
    • Slide your fingernail or plastic opening tool under the slit and pull the cover up.
  2. Samsung Admire Screen Replacement: 手順 2、 1の画像 1
    • Place your fingernail or plastic tool into the hole beneath the camera and carefully lift out the battery.
  3. Samsung Admire Screen Replacement: 手順 3、 3の画像 1 Samsung Admire Screen Replacement: 手順 3、 3の画像 2 Samsung Admire Screen Replacement: 手順 3、 3の画像 3
    • Use a Phillips #00 precision screwdriver to remove the six screws from the back of the phone.
  4. Samsung Admire Screen Replacement: 手順 4、 3の画像 1 Samsung Admire Screen Replacement: 手順 4、 3の画像 2 Samsung Admire Screen Replacement: 手順 4、 3の画像 3
    • Use the plastic opening tool to remove the inside back cover.
    • Use the plastic opening to pry the front and the back case apart.
    • As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
    • Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Screen Replacement: 手順 5、 3の画像 1 Samsung Admire Screen Replacement: 手順 5、 3の画像 2 Samsung Admire Screen Replacement: 手順 5、 3の画像 3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
  6. Samsung Admire Screen Replacement: 手順 6、 3の画像 1 Samsung Admire Screen Replacement: 手順 6、 3の画像 2 Samsung Admire Screen Replacement: 手順 6、 3の画像 3
    • Pull back on the five clips on the sides of the phone to remove the shield.
    • Be careful not to break the ribbon cables.
  7. Samsung Admire Screen Replacement: 手順 7、 3の画像 1 Samsung Admire Screen Replacement: 手順 7、 3の画像 2 Samsung Admire Screen Replacement: 手順 7、 3の画像 3
    • Use the plastic opening tool to unlatch the ribbon cable to disconnect it.
    • Place the plastic opening tool under the edge of the screen and lift the screen up carefully.
  8. Samsung Admire Screen Replacement: 手順 8、 1の画像 1
    • Insert new screen into the phone frame and reconnect the ribbon cable.
    • Follow steps in reverse order (omitting step eight) to reassemble the phone.
終わりに
12 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Thao Uyen Do
メンバー登録日: 01/20/15
896 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 7-5, Remmell Winter 2015 USF Tampa, Team 7-5, Remmell Winter 2015人のメンバー
USFT-REMMELL-W15S7G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 22
今までの合計 1,637
