この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the main display on your phone is cracked, depicting a frozen image, or not displaying an image at all, then installing a new display may fix these problems.
必要な工具と部品
To remove the back casing, firmly press down and push towards the bottom of the phone.
Locate the display screen.
Carefully squeeze part of the flat or pointed edge of the spudger into the spacing under the glass display to pry and lift the display up.
It may help to insert the pointed edge of the spudger into the small indentation shown on the right in the second image.
