はじめに
This guide may be used to help replace the hard drive from the Samsung ATIV Book 9 Lite. Have a Phillips screw driver. Be sure to keep track of all screws, and know where they belong. When removing the hard drive, be sure not to damage any connections that connect the hard drive to the computer.
ツール
パーツ
パーツは指定されていません。
Turn the laptop upside down to show the screws holding the back cover on.
Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
ある他の人がこのガイドを完成しました。
