メインコンテンツにスキップ
Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement
必要な工具と部品
  1. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Backplate: 手順 1、 2の画像 1 Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Backplate: 手順 1、 2の画像 2
    • Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
  2. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 2、 1の画像 1
    • Remove the backplate.
  3. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement, Touch-Screen: 手順 3、 1の画像 1
    • Disconnect the databus from the motherboard as seen in the lower left of the picture
    • Disconnect the white and black wire from the graphics card as seen in the middle of the photo. (Note: These two wires are connected to the motherboard by means of snap-in male-female copper connectors, meaning they can be disconnected by un-snapping the connectors.
  4. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 4、 1の画像 1
    • Using the Phillips #000 screwdriver, remove six 5mm screws.
    • These screws hold the screen assembly into place with the motherboard / electronics assembly.
  5. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 5、 1の画像 1
    • Now that the six 5mm screws were removed, remove and separate the screen assembly as seen in the image.
    • As seen in the next step, the backplate of the screen assembly will be removed. There is no hardware keeping this in place except for adhesive glue. Therefore the screen assembly backplate will be gently pried free.
  6. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 6、 1の画像 1
    • The screen assembly backplate is to be removed
    • The backplate is adhered around the edges. Using a flat-wedged tool, gently pry the backplate free from the assembly.
  7. Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 7、 2の画像 1 Samsung ATIV Book 7 NP740U3E-K01UB Touch-Screen Replacement: 手順 7、 2の画像 2
    • Now that backplate has been removed, flip the laptop over on the front. Remove the capacitive touch screen.
    • Similarly to how the backplate was adhered with glue, this touch screen is adhered to the graphics screen of this device. As seen in the second photo, the touch screen should be gently separated from the graphics screen. Make sure to disconnect the ribbon as circle in the photo.
終わりに
Important Note: When re-assembling the screen assembly, additional adhesive glue may be needed to adhere the capacitive touch-screen and screen cover back onto the original assembly.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Liam
メンバー登録日: 03/26/19
223 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G5, Simcock Spring 2019 UMass Dartmouth, Team S2-G5, Simcock Spring 2019人のメンバー
UMASSD-SIMCOCK-S19S2G5
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 485
