はじめに
This replacement guide will aid the replacement of the speakers showing you a thorough breakdown on what steps to follow to achieve this task efficiently.
必要な工具と部品
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
There are two speakers which are found on the lower left and right side of the laptop, beside the battery.
ある他の人がこのガイドを完成しました。
