メインコンテンツにスキップ
Samsung ATIV Book 4 Mouse Pad Replacement
必要な工具と部品
  1. Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 手順 1、 3の画像 1 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 手順 1、 3の画像 2 Samsung ATIV Book 4 Mouse Pad Replacement, Mouse Pad: 手順 1、 3の画像 3
    • Place the computer upside down.
    • Remove the two rubber pads, by prying up on them.
    • There may be adhesive holding them down.
    • Remove the seven 6.5mm screws on exterior of computer.
    • Remove panel by sliding it down and lifting it away from the computer.
  2. Samsung ATIV Book 4 Mouse Pad Replacement: 手順 2、 1の画像 1
    • Remove the four 4.4mm screws that are underneath the panel.
    • Remove the two 6.5mm screws that were underneath the rubber pads.
  3. Samsung ATIV Book 4 Mouse Pad Replacement: 手順 3、 2の画像 1 Samsung ATIV Book 4 Mouse Pad Replacement: 手順 3、 2の画像 2
    • Using plastic opening tool, pry plastic panel away from computer.
    • Start prying at one point and work your way around the entire computer until panel is free come computer.
    • Remove the panel from computer once all tabs are broke free.
  4. Samsung ATIV Book 4 Mouse Pad Replacement: 手順 4、 2の画像 1 Samsung ATIV Book 4 Mouse Pad Replacement: 手順 4、 2の画像 2
    • Pull this tab outwards, as shown, to release the wire harness.
    • With the tab now pulled out, pull lightly on the blue tape, to remove the harness.
    • Pull on the blue tape to remove wire harness.
    • This harness may require a little more force to remove, but will slide right out.
    • Remove the two 3.5mm screws and remove the defective hardware.
    • This step may be easier if the battery is taken out. Follow the battery replacement guide to do so.
終わりに
作成者
2人の作成者と共同で作成されました。
Daniel
メンバー登録日: 03/19/15
342 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-7, Lauer Spring 2015 Michigan Tech, Team 1-7, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G7
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,094
