メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
  1. Remove the SIM tray from the phone.
    • Remove the SIM tray from the phone.
  2. Use a heat gun or iOpener to heat the back of the phone.
    • Use a heat gun or iOpener to heat the back of the phone.
    • Insert a spudger or thin bladed tool between the batery cover and frame.
    • Slide all the way around to release the adhesive holding the cover.
    • The battery cover is also glass and can break if too much pressure is applied when removeing.
  3. Remove all 16 screws from the housing Remove all 16 screws from the housing
    • Remove all 16 screws from the housing
  4. Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
  5. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  6. Remove the Philips screw securing the mainboard.
    • Remove the Philips screw securing the mainboard.
    • Remove the cable attached to the mainboard
    • Disconnect the display and camera connectors from the mainboard
  7. Disconnect the daughter board from the mainboard Disconnect the daughter board from the mainboard
    • Disconnect the daughter board from the mainboard
  8. Using a heatgun, heat the front of the display.
    • Using a heatgun, heat the front of the display.
    • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
    • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
  9. Reattach the daughter board connector to the mainboard. When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery. Re-connect the display connector, camera and cable to the mainboard.
    • Reattach the daughter board connector to the mainboard.
    • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
    • Re-connect the display connector, camera and cable to the mainboard.
    • Screw the mainboard to the frame
  10. Turn the phone on and test the display before removing the adhesive on the back of the display.
    • Turn the phone on and test the display before removing the adhesive on the back of the display.
    • If everything works, remove the adhesive and attach the display to the plastic frame.
    • Push the display into the metal housing so it fits snugly.
  11. Replace the 16 screws that were removed in step 3. Replace the battery cover and you are done.
    • Replace the 16 screws that were removed in step 3.
    • Replace the battery cover and you are done.
終わりに
4 の人々がこのガイドを完成させました。
Harvey
メンバー登録日: 2016年02月15日
3,093 ポイント
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 55
今までの合計 2,485
