パーツ
パーツは指定されていません。
  1. Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
  2. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  3. Note: The Speaker is held in with an adhesive back so some force will be needed to remove it. Remove the speaker using a spudger and detach the cord connected to it from the laptop.  The speaker location is seen highlighted in picture 1.
    • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
    • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
    • Attach the cord of your replacement speaker and reassemble the device.
まとめ
Garrett Kissinger
メンバー登録日: 2014年02月24日
692 ポイント
5のガイドは作成済み
チーム
Michigan Tech, Team 1-2, Lauer Spring 2014 Michigan Tech, Team 1-2, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S1G2
3 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 801
