はじめに
The motherboard is the electronic hub inside the monitor connecting each of its electrical components, including the navigation button, the screen, and the HDMI/VGA ports.
必要な工具と部品
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
この手順で使用する道具:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
ある他の人がこのガイドを完成しました。
