メインコンテンツにスキップ
Samsung 27E510C NAV Button Replacement
必要な工具と部品
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: 手順 1、 3の画像 1 Samsung 27E510C  NAV Button Replacement, Back Panel: 手順 1、 3の画像 2 Samsung 27E510C  NAV Button Replacement, Back Panel: 手順 1、 3の画像 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: 手順 2、 2の画像 1 Samsung 27E510C  NAV Button Replacement: 手順 2、 2の画像 2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: 手順 3、 1の画像 1
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: 手順 4、 1の画像 1
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: 手順 5、 2の画像 1 Samsung 27E510C  NAV Button Replacement: 手順 5、 2の画像 2
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: 手順 6、 1の画像 1
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: 手順 7、 3の画像 1 Samsung 27E510C  NAV Button Replacement: 手順 7、 3の画像 2 Samsung 27E510C  NAV Button Replacement: 手順 7、 3の画像 3
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
終わりに
作成者
4人の作成者と共同で作成されました。
giggythore
メンバー登録日: 10/14/17
366 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G1
6 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 457
