メインコンテンツにスキップ
はじめに
Prereq-only guide to prepare the MiTM Air Compressors AM1PH6508HD 2012 for service.
  1. Before you begin, make sure the device is powered down and cool to the touch. Flip the engine switch into the OFF position.
    • Before you begin, make sure the device is powered down and cool to the touch.
    • Flip the engine switch into the OFF position.
  2. Grab the plastic housing at the end of the spark plug wire. Pull firmly to disconnect the wire from the spark plug.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor. Ensure the tank is completely depressurized before starting repairs.
    • Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
    • Ensure the tank is completely depressurized before starting repairs.
終わりに
Kyle Smith
メンバー登録日: 2021年02月01日
29,675 ポイント
122のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
146 メンバー
17,254のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 18
