はじめに
To repair internal components of the Saeco XSmall, the top cover must be removed. It is a large molded plastic piece which includes the top and the front. This guide will show you how to remove this.
パーツ
パーツは指定されていません。
    • Disconnect the power plug!
    • Remove pomace containers, water tank and brew unit
  1. Remove the lid of the bean container and remove all coffee beans. Remove the three Torx T10 screws securing the bean container.
    • Remove the lid of the bean container and remove all coffee beans.
    • Remove the three Torx T10 screws securing the bean container.
    • The finger guard made of black plastic for the grinder is attached with a Phillips screw. Remove it to remove the finger guard.
    • Pull the bean container vertically up and remove it.
  2. Take a picture  of the grinder or otherwise note the position of the adjuster. Pull out the grinder adjuster to the top.
    • Take a picture of the grinder or otherwise note the position of the adjuster.
    • Pull out the grinder adjuster to the top.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Place the machine on its side. At the bottom of the top cover, to the left and right of the coffee spout, are two Torx T10 screws. Remove those.
    • Place the machine on its side. At the bottom of the top cover, to the left and right of the coffee spout, are two Torx T10 screws. Remove those.
  5. The cover over the coffee spout is held by detents. To release those insert a plastic opening tool. Start at the bottom, release the cover and set it aside. The cover over the coffee spout is held by detents. To release those insert a plastic opening tool. Start at the bottom, release the cover and set it aside. The cover over the coffee spout is held by detents. To release those insert a plastic opening tool. Start at the bottom, release the cover and set it aside.
    • The cover over the coffee spout is held by detents. To release those insert a plastic opening tool. Start at the bottom, release the cover and set it aside.
  6. The top cover is now only held by detents. At the front side of bottom are two tabs that go into the bottom plate, which you have to consider when removing it Pay attention to the steam pipe Start at the back seam with opening. Gently pry with a plastic opening tool to split it.
    • The top cover is now only held by detents. At the front side of bottom are two tabs that go into the bottom plate, which you have to consider when removing it
    • Pay attention to the steam pipe
    • Start at the back seam with opening. Gently pry with a plastic opening tool to split it.
    • When the detents are released, carefully lift the cover upwards with your hand and tilt it diagonally forward. Watch for the tabs that are in the bottom plate.
    • The steam pipe is still in the front cover. You must push the cover over the steam pipe when lifting it.
  7. The coffeemaker is now open The water heater
    • The coffeemaker is now open
    • The water heater
    • The coffee grinder
まとめ
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
oldturkey03さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
VauWeh
メンバー登録日: 2015年10月19日
68,350 ポイント
56のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 7
過去 7 日: 50
過去 30 日: 257
今までの合計 1,118
