メインコンテンツにスキップ
Saeco Royal Support valve seals Replacement
必要な工具と部品
  1. Saeco Royal Support valve seals Replacement, Preparing: 手順 1、 1の画像 1
    • Unplug!
    • Remove all attachments like water tank, brewing unit etc.
    • The pictures show a Royal Cappucino One Touch HD8930, but the opening procedure is similar to all models.
  2. Saeco Royal Support valve seals Replacement, Top: 手順 2、 2の画像 1 Saeco Royal Support valve seals Replacement, Top: 手順 2、 2の画像 2
    • The coffeebean supply is fixed with two screws. Unscrew them and lift it off.
    • There is a black rubber lid under the bean hopper that you can easily lift off, leaving a large opening.
    • The adjuster of the grinder has to be solved. Mark the position or just take a picture. This type is fixed with a screw, others are only sticked together.
  3. Saeco Royal Support valve seals Replacement, Rear side: 手順 3、 1の画像 1
    • There are two screws to be turned out.
  4. Saeco Royal Support valve seals Replacement, Front: 手順 4、 3の画像 1 Saeco Royal Support valve seals Replacement, Front: 手順 4、 3の画像 2 Saeco Royal Support valve seals Replacement, Front: 手順 4、 3の画像 3
    • The screws are situated on the underneath of the cover. This type is held by four screws.
  5. Saeco Royal Support valve seals Replacement, Lift cover off: 手順 5、 2の画像 1 Saeco Royal Support valve seals Replacement, Lift cover off: 手順 5、 2の画像 2
    • Now the cover can be raised: first grip on left and right rear side and lift about 10 cm (4 in). Sometimes the cover jams a little bit.
    • Solve the hoses which lead to the water tank. Perhaps you have to pull out some contacts, (e.g. the yellow-green protection lead), don´t forget to put them on again later.
    • The cover can be drawn aslant towards the front, sliding it over the hot water pipe.
    • Most repairs can be done with the cover being laid up partially , it must not be completely removed.
  6. Saeco Royal Support valve seals Replacement, To open: 手順 6、 1の画像 1
    • On some models, the support valve is bolted to the heater. There are these instructions.
  7. Saeco Royal Support valve seals Replacement, Release support valve: 手順 7、 1の画像 1
    • The support valve is visible when the brew group has been removed. It represents the connection between the hot pressurized water and the brewing group.
    • Two big screws hold the valve, here 6mm Allen screws. To solve.
  8. Saeco Royal Support valve seals Replacement, Replacing the seals: 手順 8、 1の画像 1
    • Danger. The small sliding piece in the valve is sensitive.
    • Careful cleaning is very beneficial to the aroma.
    • The valve is single in this model. Here two seals are exchanged. For other models, it is bolted directly to the heater. In this case, remove the heater and valve and unscrew the valve. You then have to replace three seals.
  9. Saeco Royal Support valve seals Replacement: 手順 9、 1の画像 1
    • Unscrew the valve piece with a wrench SW 13.
    • Check if everything is smooth. Clean all parts well. Careful, they are sensitive.
    • The valve spring.
    • The valve stamp. Check if the gasket on the valve seat is still good. Change it if necessary.
    • The sliding piece.
    • Support seal on the thermoblock. Medium size.
    • Support gasket above. The biggest of the three.
    • Support gasket below. The smallest.
終わりに
Repeat the steps in order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VauWeh
メンバー登録日: 10/19/15
203,382 ポイント
246のガイドは作成済み
チーム
Repair is War on Entropy Repair is War on Entropy人のメンバー
Community
25 メンバー
1,121のガイドは作成済み
コメント 1 件
Wow! I dare anybody to follow these instruction for a successful repair. Terrible sequence and explanation. Just look at the pictures (they are good and clear) and try to figure out the rest.
Axxam Enni - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 60
今までの合計 7,235
