はじめに
In case you are far away from Germany or don’t want to spend the extra money sending your PM to SRM, this guide shows you how to attempt a DIY. I had no knowledge of the product design or variants of the mechanical aspects. This guide was created through observation and basic electronics knowledge. I did perform the battery swap on my own PM that I continue to use for training.
In case you are lucky to get a later model, I believe the battery replacement can now be performed by yourself.
Good Luck!
必要な工具と部品
Remove the chain rings. On some models there are little screws to open the cap. On my FSA Model there is a tab to pop open the cap.
Make sure the seals stay intact.
There are 2 batteries glued in. They are connected with a power cable that has a little 2 pin plug.
この手順で使用する道具:Desoldering Pump$3.99
ATTENTION: Make sure you don't damage the thin cooper wires marked in yellow.
Unplug the batteries from the circuit board. (red)
With the solder gun remove the cables from the old batteries. Make sure not to melt the cables or plug.
My batteries had mounting pins attached to the silver side. They have to be remove with pliers.
The terminal pins have to be bent straight.
Finally the pins have to be cut to the same length as the old batteries.
Add heat shrink to cables and solder them to battery. Red to (+) and black to (-)
Push the heat shrink up to cover the entire pin and soldering connection.
Twist the wired back together gently.
Attach the new batteries. There is a + on the circuit board on the side where the red wire goes.
Push the batteries gently back into place.
Connect the power meter and check the battery status of the sensor. On my Garmin I see NEW.
6 の人々がこのガイドを完成させました。
