メインコンテンツにスキップ
SR 306-12951100 Acoustic Guitar Tuning Keys Replacement
必要な工具と部品
  1. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 手順 1、 3の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 手順 1、 3の画像 2 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement, Tuning Keys: 手順 1、 3の画像 3
    • Remove the four outer screws.
    • Then remove the four inner screws.
    • The screws are located on the back of the guitar head.
  2. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 2、 2の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 2、 2の画像 2
    • Slide all of the collars off of the old tuning keys.
    • The collars are found on the tuning key pegs on the front head of the guitar. One of the collars is indicated in the first picture.
    • Some of the collars may be difficult to remove. Apply gentle pressure until they pop off.
  3. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 3、 3の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 3、 3の画像 2 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 3、 3の画像 3
    • Remove the old tuning keys by sliding them out of the holes.
    • It helps to put the guitar on its side and hold the head of the guitar from the front and push the old tuning keys out the back.
  4. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 4、 2の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 4、 2の画像 2
    • Clean the guitar head and tuning key holes using a microfiber cloth to ensure that the new tuning keys will fit properly.
    • This step may require more or less effort depending on how much epoxy was used to hold the old tuning keys in place.
  5. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 5、 3の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 5、 3の画像 2 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 5、 3の画像 3
    • Insert one of the new tuning key racks into the appropriate tuning key holes.
    • Both of the new tuning key pieces are identical, so either plate can be used.
    • The plate should have an overall length of 102 mm. The center to center distance between posts should be 35 mm.
  6. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 6、 3の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 6、 3の画像 2 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 6、 3の画像 3
    • Insert the second tuning key rack into the appropriate tuning key holes.
  7. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 7、 3の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 7、 3の画像 2 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 7、 3の画像 3
    • Begin installing the four outer screws.
    • Then install the four inner screws.
    • The dimensions of the screws that come with the kit are 31 mm x 35 mm x 27 mm.
    • Do not tighten the screws until all of them are in place. Once all eight screws are in, go back and tighten each one. This is done so that the new tuning keys can be properly aligned.
  8. SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 8、 2の画像 1 SR  306-12951100 Acoustic Guitar Tuning Keys Replacement: 手順 8、 2の画像 2
    • The tuning keys are now properly installed.
    • Install new guitar strings by following this video (start at 1 min 20 sec.) and this guide.
ゴール
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Michael Biancardi
メンバー登録日: 01/16/20
213 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S1-G10, Raign Spring 2020 University of North Texas, Team S1-G10, Raign Spring 2020人のメンバー
UNT-RAIGN-S20S1G10
2 メンバー
1のガイドは作成済み
2 件のコメント
I literally just bought this exact guitar at goodwill!
Hugh Bourns - 返信
Hi Michael,
I just bought this exact guitar at an estate sale this past weekend I bought it for my granddaughter to learn how to play the neck has a little bow in it and I was wondering if you knew what size the adjustment screw is and what type head it is.
Thanks!
Dennis
D Carter - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 18
今までの合計 692
