はじめに
This guide is going to show you how to open and disassemble the Sony ZS-BTG 900. By the end of the guide you will have three main areas of the device standing the alone. The three areas will be: the top, the base, and the front.
必要な工具と部品
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
How do you remove the carrying handle
Well this is stupid. You don’t show the handle being removed. I bet you broke it. You people don’t know what you are doing.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
ある他の人がこのガイドを完成しました。
