メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
How to Unlock Sony XPERIA SIM Network Lock.
ビデオの概要
  1. Make sure your phone is locked and is prompting you for a network code when a non-supported sim is inserted. Check the lock status: From Phone dealer enter this code - *#*#7378423#*#*
    • Make sure your phone is locked and is prompting you for a network code when a non-supported sim is inserted.
    • Check the lock status:
    • From Phone dealer enter this code - *#*#7378423#*#*
    • > Service info
    • > SIM lock
  2. Confirm your phone is eligible for the service. There should be an "X" before Network and the counter should show number above 0 (zero). If your counter doesn't show an "X" or shows 0 (zero) this means your phone is hardlocked and it CAN'T BE unlocked by a code. Obtain your 15-digit IMEI by dialing *#06#. Never get the IMEI from elsewhere, as it could be different from the actual IMEI.
    • Confirm your phone is eligible for the service.
    • There should be an "X" before Network and the counter should show number above 0 (zero). If your counter doesn't show an "X" or shows 0 (zero) this means your phone is hardlocked and it CAN'T BE unlocked by a code.
    • Obtain your 15-digit IMEI by dialing *#06#. Never get the IMEI from elsewhere, as it could be different from the actual IMEI.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Enter the code provided and your handset is unlocked! Enter the code provided and your handset is unlocked! Enter the code provided and your handset is unlocked!
    • Enter the code provided and your handset is unlocked!
  5. That's all!
    • That's all!
終わりに
22 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
168,953 ポイント
306のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
292 メンバー
835のガイドは作成済み
11 件のコメント
MySony experia show me (1) on network sim status……ths can be unlocked ?
sumclis william - 返信
I unlocked my Sony E5 yesterday using this website https://store.unlockboot.com/unlock-sony...
Stephan Popov - 返信
I recommend this service here to unlock your Sony XPERIA phone https://www.imeiunlocksim.com/unlock-pho...
They are great professionals in this job, have wonderful and very very fast support.
Adams Bell - 返信
i also got the same problem but seems to be worse my sony phone is hard locked and is showing 0 on the network option. how can i fix this
henry - 返信
My Sony is showing me zero how can I fix it
Osusu Felicia -
コメントを追加
統計データを表示:
過去 24時間: 109
過去 7 日: 243
過去 30 日: 1,107
今までの合計 19,185
