はじめに
This guide will be showing step-by-step instructions on how to get to and replace the motor of the airsoft gun.
  1. Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip. Slide the cover off.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws located at the bottom of the hand grip.
    • Slide the cover off.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Pull the motor out from the inside of the hand grip.
    • Pull the motor out from the inside of the hand grip.
    • Using a soldering iron and desoldering wick, desolder the wires from the motor.
  4. Using a soldering iron, solder the wires onto the new motor.
    • Using a soldering iron, solder the wires onto the new motor.
まとめ
Anika Morris
メンバー登録日: 2012年10月05日
1 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S18G41
6 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 614
