はじめに
This guide will help you remove the back cover of your device. You’ll need a Phillips #000 screwdriver to complete this guide.
必要な工具と部品
Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
Remove this screw with the Phillips #000 screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
