必要な工具と部品
Unscrew the two phillips head screws. Use the reversible screwdriver that came with the car.
Pull the cover up and slightly to the right.
Here we have to replace the filter. Lift the filter up. It comes off without difficulty.
Clean all of the rubbish and insects that are inside.
Place the new filter, fitting the rubber contour with the gap.
Fit the two tabs in their places.
Once you've done that, put the two screws into their places and tightly screw them in. Finally, check to see that they are completely screwed in.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Mr. Beanさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
