はじめに
If your Ryobi RS290G bearing assembly is loose or causing traction pad issues, this guide will show you how to successfully replace the bearing assembly.
必要な工具と部品
もう少しです!
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
終わりに
