メインコンテンツにスキップ
Ryobi RJ1861V Saw Gear Assembly Replacement
必要な工具と部品
  1. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Bar Assembly: 手順 1、 1の画像 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 2、 2の画像 1 Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 2、 2の画像 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 3、 1の画像 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 4、 1の画像 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 5、 1の画像 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 6、 1の画像 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 7、 1の画像 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Saw Gear Assembly Replacement, Assembly Bar Bearing: 手順 8、 1の画像 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 9、 1の画像 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 10、 1の画像 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Saw Gear Assembly Replacement, Saw Gear Assembly: 手順 11、 1の画像 1
    • After you remove the bearing, stand the device with the gear assembly facing up.
  12. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 12、 1の画像 1
    • The gear assembly will be covered in industrial lubricant, so wipe away an excess with a rag to reveal three screws.
  13. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 13、 1の画像 1
    • Remove three screws with a Torx bit and screw driver.
  14. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 14、 1の画像 1
    • Rotate the device 180 degrees and apply pressure to the gear assembly through the small hole, extra force may be needed in this step to break it loose.
  15. Ryobi RJ1861V Saw Gear Assembly Replacement: 手順 15、 1の画像 1
    • Once the gear assembly has broken free rotate the device again and lift it out of the gear housing.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Morgan Doyle
メンバー登録日: 04/08/19
316 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 920
