はじめに
This replacement guild will should how to replace the motor in the Ryobi RJ1861V.
必要な工具と部品
Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
The motor is divided into two sections, one attached to the gear case and one attached to the handle.
This arrow indicates the section attached to the gear case.
This arrow indicates the section attached to the handle.
ある他の人がこのガイドを完成しました。
