メインコンテンツにスキップ
Ryobi P235 Motor Replacement
必要な工具と部品
  1. Ryobi P235 Motor Replacement, Battery: 手順 1、 2の画像 1 Ryobi P235 Motor Replacement, Battery: 手順 1、 2の画像 2
    • Push in both push tabs on the battery at the same time.
    • They are located below the green housing and are in the middle on both sides of the battery.
  2. Ryobi P235 Motor Replacement: 手順 2、 2の画像 1 Ryobi P235 Motor Replacement: 手順 2、 2の画像 2
    • Pull the battery away from the drill housing while holding in both tabs.
  3. Ryobi P235 Motor Replacement, Motor: 手順 3、 2の画像 1 Ryobi P235 Motor Replacement, Motor: 手順 3、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
  4. Ryobi P235 Motor Replacement: 手順 4、 2の画像 1 Ryobi P235 Motor Replacement: 手順 4、 2の画像 2
    • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
  5. Ryobi P235 Motor Replacement: 手順 5、 2の画像 1 Ryobi P235 Motor Replacement: 手順 5、 2の画像 2
    • Open the housing with the data label facing up.
  6. Ryobi P235 Motor Replacement: 手順 6、 1の画像 1
    • Lift the motor and chuck assembly out of the housing.
  7. Ryobi P235 Motor Replacement: 手順 7、 2の画像 1 Ryobi P235 Motor Replacement: 手順 7、 2の画像 2
    • Remove the gear case and sleeve bearing assembly from the inner case assembly.
  8. Ryobi P235 Motor Replacement: 手順 8、 2の画像 1 Ryobi P235 Motor Replacement: 手順 8、 2の画像 2
    • Remove the cam shaft and motor assembly.
  9. Ryobi P235 Motor Replacement: 手順 9、 3の画像 1 Ryobi P235 Motor Replacement: 手順 9、 3の画像 2 Ryobi P235 Motor Replacement: 手順 9、 3の画像 3
    • Remove the metal pins on each side of the inner case assembly.
    • It is easiest to push the pin through the opening from one side and once enough of the pin is through, grab it with the tweezers and pull it the rest of the way through.
    • When reassembling, make sure the pin goes in straight and makes it out the other side, rather than going in diagonally and into the inner case assembly.
  10. Ryobi P235 Motor Replacement: 手順 10、 2の画像 1 Ryobi P235 Motor Replacement: 手順 10、 2の画像 2
    • Remove the ring gear.
    • To help lift the ring gear out of the inner case assembly, wedge the spudger under one side, moving it up by a little, then switch to the other side and repeat until the gear ring is out.
  11. Ryobi P235 Motor Replacement: 手順 11、 3の画像 1 Ryobi P235 Motor Replacement: 手順 11、 3の画像 2 Ryobi P235 Motor Replacement: 手順 11、 3の画像 3
    • Remove the two 8mm screws and spring washers connecting the motor to the inner case assembly.
    • Separate the two parts.
  12. Ryobi P235 Motor Replacement: 手順 12、 3の画像 1 Ryobi P235 Motor Replacement: 手順 12、 3の画像 2 Ryobi P235 Motor Replacement: 手順 12、 3の画像 3
    • Use a soldering iron to remove the black and red wires connecting the motor to the trigger assembly.
    • Use the soldering iron to connect the new motor to the trigger assembly.
    • Make sure the red wire connects to the lead with the red mark on it.
終わりに
To reassemble your device, follow these instructions in reverse.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Paul Sousa
メンバー登録日: 10/29/19
805 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019人のメンバー
UMASSD-SALOMAN-F19S4G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 38
今までの合計 1,625
