メインコンテンツにスキップ
Ryobi P202 Trigger Assembly Replacement
必要な工具と部品
  1. Ryobi P202 Trigger Assembly Replacement, Battery: 手順 1、 3の画像 1 Ryobi P202 Trigger Assembly Replacement, Battery: 手順 1、 3の画像 2 Ryobi P202 Trigger Assembly Replacement, Battery: 手順 1、 3の画像 3
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Trigger Assembly Replacement, Right Side Case: 手順 2、 2の画像 1 Ryobi P202 Trigger Assembly Replacement, Right Side Case: 手順 2、 2の画像 2
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Trigger Assembly Replacement: 手順 3、 2の画像 1 Ryobi P202 Trigger Assembly Replacement: 手順 3、 2の画像 2
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 手順 4、 2の画像 1 Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 手順 4、 2の画像 2
    • Grip the battery clip and pull straight up to remove the metal battery contacts.
    • You can now clean the metal battery contacts with isopropyl alcohol.
  5. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 手順 5、 2の画像 1 Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 手順 5、 2の画像 2
    • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
  6. Ryobi P202 Trigger Assembly Replacement: 手順 6、 2の画像 1 Ryobi P202 Trigger Assembly Replacement: 手順 6、 2の画像 2
    • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
    • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
    • The trigger assembly is Part #: 270001392
終わりに
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Joseph Eckstein
メンバー登録日: 04/07/15
1,596 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015人のメンバー
CPSU-FORTE-S15S17G6
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 29
今までの合計 4,834
