メインコンテンツにスキップ
Ryobi D620H Motor Brush Replacement
必要な工具と部品
  1. Ryobi D620H Motor Brush Replacement, Right Side Case: 手順 1、 1の画像 1
    • All nine 16mm long Torx20 screws (Circled in red).
    • Turn the screwdriver counterclockwise to loosen the screws.
    • Remove all nine screws completely.
    • Place in parts tray (Optional)
  2. Ryobi D620H Motor Brush Replacement: 手順 2、 2の画像 1 Ryobi D620H Motor Brush Replacement: 手順 2、 2の画像 2
    • Pry the right side of the case off to expose the internal components.
  3. Ryobi D620H Motor Brush Replacement, Motor Brush: 手順 3、 1の画像 1
    • The motor brushes are located on the rotating armature of the motor.
    • Look for the large dark gray metal housing in the center of the body of the drill, this is the motor.
    • The armature of the motor by finding the chuck and the transfer gears, and then look at the other end of the motor. There is a small copper barrel (armature) that is likely colored dark gray from the carbon brushes rubbing against the armature.
    • On the top and bottom of the armature (small copper barrel), there are brass spring-loaded brackets holding blocks of carbon against the armature; these blocks are the motor brushes.
  4. Ryobi D620H Motor Brush Replacement: 手順 4、 2の画像 1 Ryobi D620H Motor Brush Replacement: 手順 4、 2の画像 2
    • Unscrew the brass spring-loaded bracket from the case using a PH1 screwdriver and remove them from the case and armature.
    • The motor brush will likely partialy self-eject from the brass brackets.
    • It is highly recommended to replace one motor brush at a time to not mix up the wiring.
    • Unscrewing the brush brackets is the same for both top and bottom.
  5. Ryobi D620H Motor Brush Replacement: 手順 5、 1の画像 1
    • Pull the two connections (circled in red) gently from their terminals.
    • The longer white wire connects to the left side terminal and the shorter white wire connected to the brush connects to the right side terminal
    • Remove the composite shim under the bracket.
  6. Ryobi D620H Motor Brush Replacement: 手順 6、 1の画像 1
    • Remove screws and disconnect the two terminals circled in red on the bottom brush bracket.
    • Remove the longer black wire that connects to the left side terminal
    • Remove the shorter white wire connected to the brush that connects to the right side terminal
    • Remove composite shim under the bracket.
  7. Ryobi D620H Motor Brush Replacement: 手順 7、 2の画像 1 Ryobi D620H Motor Brush Replacement: 手順 7、 2の画像 2
    • This process is identical for the top and bottom brushes as they are mirrored.
    • Remove the right-side wire from terminal. (The wire that connects to the brush).
    • Pull the brush out of the brackets gently. It shouldn't require much force.
  8. Ryobi D620H Motor Brush Replacement: 手順 8、 2の画像 1 Ryobi D620H Motor Brush Replacement: 手順 8、 2の画像 2
    • Place the new coil spring on the new bracket.
    • Slide the motor brush wire into the bracket and connect it to the right-side terminal.
    • Reconnect the longer white wire on the top brackets left side terminal by firmly and steadily pushing down.
    • Reconnect the longer black wire on the bottom bracket left side terminal by firmly and steadily pushing down.
    • Replace the composite shim under the brackets.
    • Screw both brackets down.
終わりに
You've successfully replaced the motor brushes on your Ryobi Hammer Drill!
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jacob da Ponte
メンバー登録日: 10/30/23
469 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 1-2, Petersen Fall 2023 UMass Dartmouth, Team 1-2, Petersen Fall 2023人のメンバー
UMASSD-PETERSEN-F23S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 38
今までの合計 192
