メインコンテンツにスキップ
How to Run First Aid with Disk Utility
  1. How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 手順 1、 2の画像 1 How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 手順 1、 2の画像 2
    • Open Disk Utilities, which can be found in the Applications folder under Utilities
    • Pro Tip: Take the shortcut and use Spotlight. (This method is used in this guide)
  2. How to Run First Aid with Disk Utility: 手順 2、 2の画像 1 How to Run First Aid with Disk Utility: 手順 2、 2の画像 2
    • Once the Disk Utility App opens, click the "View" menu.
    • Select "Show All Devices"
    • Older versions of macOS may not have this button. If so, skip to the next step.
  3. How to Run First Aid with Disk Utility: 手順 3、 1の画像 1
    • In the Sidebar, click the last volume in the list.
    • By default it will likely be named "Macintosh HD - Data" or simply "Macintosh HD" on Macs running 10.14 Mojave or earlier.
  4. How to Run First Aid with Disk Utility: 手順 4、 3の画像 1 How to Run First Aid with Disk Utility: 手順 4、 3の画像 2 How to Run First Aid with Disk Utility: 手順 4、 3の画像 3
    • Click on the First Aid button at the top of the window.
    • A dialogue box will appear asking if you would like to run First Aid.
    • Click "Run".
    • A second dialogue box will pop up prompting for acknowledgement that verifying your startup disk will cause it to be non-responsive.
    • Click “Continue”.
  5. How to Run First Aid with Disk Utility: 手順 5、 3の画像 1 How to Run First Aid with Disk Utility: 手順 5、 3の画像 2 How to Run First Aid with Disk Utility: 手順 5、 3の画像 3
    • This procedure will take a few minutes to complete. The machine may freeze up, or lock up during this procedure.
    • Patience is key here.
    • Disk repair may fail, or give an error message. Restart your machine and run it again if this is the case, it may repair further issues.
    • Once completed, click done.
    • Pro Tip: To see the entire process including corrected errors, click on the arrow next to 'Show Details'.
    • Repeat this on all items in the Disk Utility list for your internal drive. Move upward through the list. Order of operations is all volumes first, then the container and finally the disk itself.
  6. How to Run First Aid with Disk Utility: 手順 6、 1の画像 1
    • If you continue to receive errors, repeat this process using the Disk Utility function in Internet Recovery.
終わりに
Close Disk Utility, and the internal drive should be ready to go.
39 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Mike
メンバー登録日: 11/01/10
14,243 ポイント
3のガイドは作成済み
チーム
Mike's Super Duper Computer Repairs Mike's Super Duper Computer Repairs人のメンバー
Business
1 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 61
過去 30 日: 291
今までの合計 14,677
