はじめに
This guide shows how to remove and replace the spray button on a Rug Doctor. The handle must be detached from the body and opened up in order to remove the button.
必要な工具と部品
Uncoil the power cable from the handle.
Remove the sixteen Phillips fasteners of the following lengths:
Six 22.7 mm machine screws
Four 35.3 mm machine screws
Two 25.2 mm (thicker) machine screws
Two 48.4 mm bolts with washers
Two 30.1 mm screws
Use your fingers to push the black plunger down towards the bottom of the handle into position. This may take significant force.
Once the plunger slips into position, squeeze the the two handle halves together.
If that doesn't happen, check to see if the plunger is properly positioned, and that no wires are pinched.
Continue squeezing the two handle halves together while you reinstall the handle's lower screws.
To reassemble your device, follow these instructions in reverse order while noting the re-assembly tips.
11 の人々がこのガイドを完成させました。
