メインコンテンツにスキップ
Rubber Watch Battery Replacement
必要な工具と部品
  1. Rubber Watch Battery Replacement, Battery: 手順 1、 2の画像 1 Rubber Watch Battery Replacement, Battery: 手順 1、 2の画像 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: 手順 2、 3の画像 1 Rubber Watch Battery Replacement: 手順 2、 3の画像 2 Rubber Watch Battery Replacement: 手順 2、 3の画像 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: 手順 3、 1の画像 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: 手順 4、 3の画像 1 Rubber Watch Battery Replacement: 手順 4、 3の画像 2 Rubber Watch Battery Replacement: 手順 4、 3の画像 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: 手順 5、 1の画像 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: 手順 6、 1の画像 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: 手順 7、 3の画像 1 Rubber Watch Battery Replacement: 手順 7、 3の画像 2 Rubber Watch Battery Replacement: 手順 7、 3の画像 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
ゴール
作成者
2人の作成者と共同で作成されました。
Lee
メンバー登録日: 04/28/17
110 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S2-G5, Cole Spring 2017 UC Davis, Team S2-G5, Cole Spring 2017人のメンバー
UCD-COLE-S17S2G5
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 13
今までの合計 759
