メインコンテンツにスキップ
Royal Kludge GK64 Keyboard Switch Spring Replacement
必要な工具と部品
  1. Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 手順 1、 2の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement, Keyboard Switch Spring: 手順 1、 2の画像 2
    • Use a keycap remover to pull your keycap up and off of the keyboard.
    • Remove any keycaps surrounding the one you are working on if you need more space.
  2. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 2、 3の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 2、 3の画像 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 2、 3の画像 3
    • Use the switch puller to pull the desired switch out of your keyboard.
  3. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 3、 2の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 3、 2の画像 2
    • Place your switch onto your switch opener, and gently push down.
    • Make sure the switch is securely in place and continue to remove the top housing.
  4. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 4、 3の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 4、 3の画像 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 4、 3の画像 3
    • Use the stem holder to remove the stem, which will reveal the switch spring.
    • Remove the switch spring.
  5. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 5、 2の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 5、 2の画像 2
    • Align your new spring with the center of the bottom housing and gently place the switch spring.
  6. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 6、 3の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 6、 3の画像 2 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 6、 3の画像 3
    • To put the stem back, align the stem legs with the metal plate on the switch.
    • Remove the switch from the switch opener.
    • Gently push down onto the housing until you hear a click and both pieces are into place.
  7. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 7、 2の画像 1 Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 7、 2の画像 2
    • Align the pins located at the bottom of the switch to the corresponding pin holes in the keyboard.
    • Gently push the switch back into the keyboard.
  8. Royal Kludge GK64 Keyboard Switch Spring Replacement: 手順 8、 1の画像 1
    • Place the keycap back onto the switch and push down to secure the keycap.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Diksha Sakre
メンバー登録日: 09/19/22
228 ポイント
1ガイドが承認済み
チーム
York University, Team A-7, Morris Fall 2022 York University, Team A-7, Morris Fall 2022人のメンバー
YORK-MORRIS-F22SAG7
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 346
