はじめに
The tip switch is a bulb filled with mercury that turns a heater off if the device were to tip over. This function is to prevent fires and if the heater continues to run even when tipped over then replace the tip switch.
必要な工具と部品
Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
もう少しです!
終わりに
