メインコンテンツにスキップ
Royal Heat RS-100 Switch and Circuit Board Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement, Panel: 手順 1、 1の画像 1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 2、 3の画像 1 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 2、 3の画像 2 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 2、 3の画像 3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 3、 1の画像 1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement, Switch and Circuit Board Assembly: 手順 4、 1の画像 1
    • Remove the two 10 mm Phillips screws using a #2 Phillips screw driver. One attaches the gold metal bracket to the heater coil housing and the other attaches the fuse holder to heater coil housing.
  5. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 5、 2の画像 1 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 5、 2の画像 2
    • Make note of where you disconnect the wires from so you can properly connect them when re-assembling heater.
    • Unplug the wire that goes from the bottom of the power switch to the heater coils. To unplug pull down on the wire until it breaks free.
  6. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 6、 2の画像 1 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 6、 2の画像 2
    • Unplug the wire that goes from the bottom of the power switch to the fuse holder. To unplug the wire, pull the wire away from the fuse holder.
  7. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 7、 1の画像 1
    • Unplug the wires located on the right side of the heat coil housing. Both plugs will come off together. To unplug the wires, pull down on the wire until it breaks free.
  8. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 8、 2の画像 1 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 8、 2の画像 2
    • Grab the Switch and Circuit Board Assembly with one hand and slide it up. You will need to wiggle it to break it loose. While wiggling it, slide it up until it is clear of the plastic rails.
  9. Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 9、 2の画像 1 Royal Heat RS-100 Switch and Circuit Board Assembly Replacement: 手順 9、 2の画像 2
    • Unplug the two wires, with blue ends, that go from the Power/Fan switch and from the bottom of the Circuit Board to the fan. To unplug the wires, pull them away from the fan assembly until they break free.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jorge Revelo
メンバー登録日: 10/14/13
215 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-35, Amido Fall 2013 Cal Poly, Team 11-35, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G35
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 83
