メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Royal Heat RS-100 Fan Replacement
必要な工具と部品
  1. Royal Heat RS-100 Fan Replacement, Panel: 手順 1、 1の画像 1
    • Unplug the power cord.
    • Flip the device over so the bottom is facing up.
    • Remove the two 10mm screws holding the back panel using a Phillips #2 screwdriver.
  2. Royal Heat RS-100 Fan Replacement: 手順 2、 3の画像 1 Royal Heat RS-100 Fan Replacement: 手順 2、 3の画像 2 Royal Heat RS-100 Fan Replacement: 手順 2、 3の画像 3
    • Place the Flathead Screw driver parallel with the gap between the back and the heater body, then twist until the two parts of panel are separated. You may have to do this on four sides of the panel.
    • Remove the front panel by pulling them apart. The front panel should come out easily.
  3. Royal Heat RS-100 Fan Replacement: 手順 3、 1の画像 1
    • Remove the two dial caps from the two switches by lifting them up.
  4. Royal Heat RS-100 Fan Replacement, Fan: 手順 4、 1の画像 1
    • Remove the three 10 mm screws that attach the fan to the heating coil assembly using the #2 Phillip Screwdriver.
  5. Royal Heat RS-100 Fan Replacement: 手順 5、 1の画像 1
    • Remove the 10 mm screw that attaches the fan to the heating coil assembly using the #2 Phillip Screwdriver.
  6. Royal Heat RS-100 Fan Replacement: 手順 6、 1の画像 1
    • Lift the heating coil assembly from the fan.
  7. Royal Heat RS-100 Fan Replacement: 手順 7、 1の画像 1
    • Unplug the two blue wires that connect the fan to the Power/Fan Switch Circuit Board Assembly by pulling them away them from the fan.
  8. Royal Heat RS-100 Fan Replacement: 手順 8、 1の画像 1
    • Flip the device over so the back panel is facing upwards.
  9. Royal Heat RS-100 Fan Replacement: 手順 9、 1の画像 1
    • Gently pry the back screen off of the device using a flathead screwdriver and remove it.
  10. Royal Heat RS-100 Fan Replacement: 手順 10、 1の画像 1
    • Remove the four 10mm screws that attach the fan to the heater case using the #2 Phillip Screwdriver.
    • Lift the back plate from the fan by pulling it away from the fan.
    • Take note the direction of the fan blades. Putting the the fan in the wrong way will result in the air flow to come out the back of the device instead of the front.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Danyele Rampone
メンバー登録日: 10/15/13
125 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-35, Amido Fall 2013 Cal Poly, Team 11-35, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G35
4 メンバー
13のガイドは作成済み
1件のガイドコメント
QUESTION OFF TOPIC>>> sorry but don't know who else to ask..
Anyone know if Royal Heat is still in business maybe under a different name? I cannot find anything on the market today that compares to this little heater/fan. Was given one by elderly relative who said he has used it for 20 years and STILL works wonderfully. Poor fellow confined to a nursing home now and said he doesn't need it.
Thank You
Michael Gray - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 54
今までの合計 1,031
