メインコンテンツにスキップ
Royal Enfield:How to Clean Final Drive Chain
  1. Royal Enfield:How to Clean Final Drive Chain, Things Required: 手順 1、 3の画像 1 Royal Enfield:How to Clean Final Drive Chain, Things Required: 手順 1、 3の画像 2 Royal Enfield:How to Clean Final Drive Chain, Things Required: 手順 1、 3の画像 3
    • Things required:
    • 1. A bottle of 500 ml diesel or any low solvent oil, like kerosene 2. A used toothbrush 3. A can 4. Clean cotton cloth. 5 Motul Chain lube C-2 6. Hand wrench no.10
  2. Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 手順 2、 3の画像 1 Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 手順 2、 3の画像 2 Royal Enfield:How to Clean Final Drive Chain, Cleaning The Chain: 手順 2、 3の画像 3
    • 1. Keep the motorcycle in centre stand. 2. Unscrew the two screws of Chain Cover and remove the cover. 3. Pour some quantity of diesel to a clean container. 4. Dip the toothbrush in diesel. 5. Start brushing the rollers and both sides of the chain thoroughly while rotating the rear tyre slowly. 6. Once done wipe the chain with the cotton cloth.
  3. Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: 手順 3、 2の画像 1 Royal Enfield:How to Clean Final Drive Chain, Lubing the Chain: 手順 3、 2の画像 2
    • 7. Now spray the Motul Chain lube C-2 from a close distance while rotating the rear tyre slowly. 8. Wait for 10 minutes. 9. Put the Chain Cover in appropriate position and tight the screws.
終わりに
11 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
soumitra sengupta
メンバー登録日: 02/04/16
424 ポイント
1ガイドが承認済み
コメント 1 件
Two points, why Diesel SHOUDN'T be used! First: The Diesel will attack the seals between the rings of the chain, wich prevent the lifetime grease filling to come out (same thing with Kerosine, Petroleum, Gasoline and high concentrations of any alcohol). If the Grease filling already came out, the chain is still useable, but it will wear out very fast. Second point is that the Diesel (which is pretty toxic and harmful to animals and humans) goes on the street and the next rain will take it in the nature. So DON'T use it! Don't wanna make advertisement, but I'm using the products from GreenOil, wich are 100% plant based and completely Biodegradable (http://www.green-oil.net). If you don't wanna take this, use something wich is declared as a special motorcycle chain cleaning product and compatible with O-,X-,W-Chains (probably Motul has one of these in their programs).
Leonard Kesting - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 167
今までの合計 7,399
