メインコンテンツにスキップ
Rowenta Focus Material Setting Knob Replacement
必要な工具と部品
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: 手順 1、 2の画像 1 Rowenta Focus Material Setting Knob Replacement, Power Assembly: 手順 1、 2の画像 2
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
  2. Rowenta Focus Material Setting Knob Replacement: 手順 2、 3の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 2、 3の画像 2 Rowenta Focus Material Setting Knob Replacement: 手順 2、 3の画像 3
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
  3. Rowenta Focus Material Setting Knob Replacement: 手順 3、 2の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 3、 2の画像 2
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
  4. Rowenta Focus Material Setting Knob Replacement: 手順 4、 2の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 4、 2の画像 2
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
  5. Rowenta Focus Material Setting Knob Replacement: 手順 5、 3の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 5、 3の画像 2 Rowenta Focus Material Setting Knob Replacement: 手順 5、 3の画像 3
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 手順 6、 3の画像 1 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 手順 6、 3の画像 2 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 手順 6、 3の画像 3
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
  7. Rowenta Focus Material Setting Knob Replacement: 手順 7、 3の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 7、 3の画像 2 Rowenta Focus Material Setting Knob Replacement: 手順 7、 3の画像 3
    • Replace with an identical part by inserting it into the space.
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 手順 8、 2の画像 1 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 手順 8、 2の画像 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
  9. Rowenta Focus Material Setting Knob Replacement: 手順 9、 2の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 9、 2の画像 2
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
  10. Rowenta Focus Material Setting Knob Replacement: 手順 10、 2の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 10、 2の画像 2
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
  11. Rowenta Focus Material Setting Knob Replacement: 手順 11、 3の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 11、 3の画像 2 Rowenta Focus Material Setting Knob Replacement: 手順 11、 3の画像 3
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
  12. Rowenta Focus Material Setting Knob Replacement: 手順 12、 3の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 12、 3の画像 2 Rowenta Focus Material Setting Knob Replacement: 手順 12、 3の画像 3
    • Lift the iron up using the handle to completely detach the soleplate.
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 手順 13、 3の画像 1 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 手順 13、 3の画像 2 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 手順 13、 3の画像 3
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
  14. Rowenta Focus Material Setting Knob Replacement: 手順 14、 2の画像 1 Rowenta Focus Material Setting Knob Replacement: 手順 14、 2の画像 2
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Bella Navarro
メンバー登録日: 09/03/21
450 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 2-3, Bedsole Fall 2021 University of Alabama, Team 2-3, Bedsole Fall 2021人のメンバー
UA-BEDSOLE-F21S2G3
4 メンバー
9のガイドは作成済み
1件のガイドコメント
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 43
今までの合計 1,863
