はじめに
If the power switch is stuck or not functioning anymore, you will need to replace the power switch circuit board. in order to replace the power switch circuit board you will need to remove the saw casing and motor assembly.
必要な工具と部品
Orient the saw so that the handle is closest to you and the saw end points towards the left.
ある他の人がこのガイドを完成しました。
1件のガイドコメント
Nice guide, I can’t seem to find the switch online, it seems to be discontinued
