メインコンテンツにスキップ
RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement
必要な工具と部品
  1. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement, Saw Casing: 手順 1、 1の画像 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 2、 2の画像 1 RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 2、 2の画像 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 3、 2の画像 1 RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 3、 2の画像 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 4、 1の画像 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 5、 2の画像 1 RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 5、 2の画像 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement, Motor: 手順 6、 1の画像 1
    • Lift the motor assembly out of the casing.
    • The white plastic piece connecting the wires and holding the motor brushes in place is fragile. Be careful to not break it when removing the motor assembly.
  7. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 7、 2の画像 1 RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 7、 2の画像 2
    • Detach the wire connected to the bottom of the motor assembly.
    • Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
  8. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement, Power Switch Circuit Board: 手順 8、 2の画像 1 RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement, Power Switch Circuit Board: 手順 8、 2の画像 2
    • Slide the red bumper switch off the casing.
    • The power cord is not shown, but does not need to be removed.
  9. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 9、 1の画像 1
    • Pinch the two white clips with your thumb while simultaneously pulling the black and white wires.
    • The motor assembly is shown in this picture, do not worry about it since you have removed it in the previous steps.
  10. RotoZip Rebel REB01 Type 2 Switch Circuit Board Replacement: 手順 10、 1の画像 1
    • Pull the circuit board upward to remove it from the casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Lauren Russell
メンバー登録日: 10/05/16
224 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G4
4 メンバー
5のガイドは作成済み
コメント 1 件
Nice guide, I can’t seem to find the switch online, it seems to be discontinued
Andrew Doble - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 22
今までの合計 2,837
