メインコンテンツにスキップ
RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement
必要な工具と部品
  1. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Saw Casing: 手順 1、 1の画像 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 2、 2の画像 1 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 2、 2の画像 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 3、 2の画像 1 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 3、 2の画像 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 4、 1の画像 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 5、 2の画像 1 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 5、 2の画像 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Motor: 手順 6、 1の画像 1
    • Lift the motor assembly out of the casing.
    • The white plastic piece connecting the wires and holding the motor brushes in place is fragile. Be careful to not break it when removing the motor assembly.
  7. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 7、 2の画像 1 RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 7、 2の画像 2
    • Detach the wire connected to the bottom of the motor assembly.
    • Rotate the motor away from you so that the second wire is visible, and detach that wire as well.
  8. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement, Safety Lock Pin: 手順 8、 1の画像 1
    • Remove the sliding washer holding the pin in place.
    • The sliding washer is not shown in this guide. The action shows where the washer should be located.
  9. RotoZip Rebel REB01 Type 2 Safety Lock Pin Replacement: 手順 9、 1の画像 1
    • Flip the saw so that the 'Rotozip' label is facing upwards.
    • Remove the safety lock pin and spring.
終わりに
作成者
3人の作成者と共同で作成されました。
Lauren Russell
メンバー登録日: 10/05/16
224 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G4
4 メンバー
5のガイドは作成済み
1件のガイドコメント
Where can I find replacement parts for this Particular rotozip model #reb01 type 2
Kennith Murray - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 2,446
