メインコンテンツにスキップ
RotoZip Rebel REB01 Type 2 Power Cord Replacement
必要な工具と部品
  1. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Saw Casing: 手順 1、 1の画像 1
    • Unplug the saw before attempting any of the replacement guides.
    • Orient the saw so that the handle is closest to you and the saw end points towards the left.
  2. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 2、 2の画像 1 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 2、 2の画像 2
    • Push down on the grey lock on the right side of the handle to unlock it.
    • Pull the handle to detach it from the saw.
  3. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 3、 2の画像 1 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 3、 2の画像 2
    • Lift the black lock at the tip of the saw to unlock the depth gauge.
    • Pull the depth gauge to detach it from the saw.
  4. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 4、 1の画像 1
    • Rotate the device so that the bottom of the saw is facing upwards.
    • Remove the six 20mm screws with a 6mm flathead screwdriver.
  5. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 5、 2の画像 1 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 5、 2の画像 2
    • Cut through the stickers on the right and left sides of the saw using a metal spudger.
    • Pull off the top half of the casing.
  6. RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: 手順 6、 2の画像 1 RotoZip Rebel REB01 Type 2 Power Cord Replacement, Power Cord: 手順 6、 2の画像 2
    • Remove the two 14 mm screws on the plastic plate holding the power cord with a flat head screwdriver.
    • Lift off the plastic plate holding the power cord with a tweezer.
  7. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 7、 1の画像 1
    • Pull the switchboard out slowly.
    • The power switch will also come out. Set it on the side.
  8. RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 8、 2の画像 1 RotoZip Rebel REB01 Type 2 Power Cord Replacement: 手順 8、 2の画像 2
    • Pinch the two white clips with your thumb while simultaneously removing the black and white wires.
    • Remove the power cord from the saw.
    • When reassembling, make sure to plug the black wire into the top clip.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ezzeddeen Gazali
メンバー登録日: 10/06/16
81 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-4, Livingston Fall 2016 Cal Poly, Team 4-4, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 654
