メインコンテンツにスキップ
Rosewill NEON M62 Side Buttons Replacement
必要な工具と部品
  1. Rosewill NEON M62 Side Buttons Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Place the mouse so the bottom is facing upwards.
    • Remove the plastic skates.
    • These are not shown in the picture since they were missing from the device.
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  2. Rosewill NEON M62 Side Buttons Replacement: 手順 2、 1の画像 1
    • Use the opening tool along the side of the mouse to open up it.
    • This may take multiple attempts to do so; be patient and careful not to break the mouse.
  3. Rosewill NEON M62 Side Buttons Replacement: 手順 3、 2の画像 1 Rosewill NEON M62 Side Buttons Replacement: 手順 3、 2の画像 2
    • Loosen the top and bottom half of the mouse with the opening tool, and slowly pull up the bottom half of the mouse.
  4. Rosewill NEON M62 Side Buttons Replacement, Top Cover: 手順 4、 2の画像 1 Rosewill NEON M62 Side Buttons Replacement, Top Cover: 手順 4、 2の画像 2
    • Hold the top half of the mouse with your non-dominant hand.
    • With your dominant hand, push an opening tool into the gaps in the panel.
    • Pry the panel off.
  5. Rosewill NEON M62 Side Buttons Replacement, Side Buttons: 手順 5、 1の画像 1
    • Using the opening tool, take the mouse 1 and mouse 2 buttons off the top of the mouse.
  6. Rosewill NEON M62 Side Buttons Replacement: 手順 6、 1の画像 1
    • Remove the mouse 1 and mouse 2 buttons.
  7. Rosewill NEON M62 Side Buttons Replacement: 手順 7、 1の画像 1
    • Place the mouse on its back.
  8. Rosewill NEON M62 Side Buttons Replacement: 手順 8、 1の画像 1
    • Move around the mouse piece with an opening tool, and loosen up the piece.
  9. Rosewill NEON M62 Side Buttons Replacement: 手順 9、 1の画像 1
    • Grab the mouse piece and take it out.
  10. Rosewill NEON M62 Side Buttons Replacement: 手順 10、 1の画像 1
    • You're now ready to replace the side buttons.
終わりに
作成者
3人の作成者と共同で作成されました。
Sean Turk
メンバー登録日: 03/16/23
217 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-2, Ryckebusch Spring 2023人のメンバー
UMASSD-RYCKEBUSCH-S23S7G2
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 62
